I just finished a complete interior restoration on my 71. As part of the restoration, I replaced the headlight switch and all instrument gauge bulbs. After I reinstalled all of the dash pads and buttoned everything up, I discovered that none of the gauge lights worked. What's strange, is that I tested them immediately after installing the driver's side pad and the center instrument cluster and everything was ok. I checked the fuse (lower right of fuse panel the one marked "gages") and it's ok. The headlights,taillights, side marker lights work, which tells me the headlight switch is functioning. What could my problem be?
John
John
