I have all the parts on the front end from the underhood/front susp restoration except the hood and upper radiator shroud.
When I went to put on the upper shroud (NOS) it will not go down far enough. It stops on the frame about 3/4" from where the holes will line up with the rad support nuts. I see on the old shroud that the tabs were bent up or gone. I also see that the inner wheelhouses are sitting on the frame.
The only way I see around this is to loosen all the frame to body fasteners (bumper brackets, frame to bumper bracket braces) and lift the front end up and then retighten.
Is this the right tact? Is this a common problem? How do I lift the front end w/o cracking fiber glass?
thanks
thanks
