Completely rebuilt the brakes on my '73. Rebuilt calipers, new brake lines, new linings. Used the old master cylinder (it looked quite new) and combination valve. I thought I had bled them thoroughly, but I had to do it manually without the use of a vacuum pump or bleeding kit.
The brakes are now very mushy. The pedal will go all the way to the floor and barely engage the linings to the disc. If I first pump the brakes with two quick strokes before attempting to stop, they work pretty well.
Does it sound like I failed to bleed all of the air from the lines? I've done this several times and I'm not seeing any air bubbles. Or does it sound like the master cylinder is malfunctioning, or perhaps something else?
