1966 CORVETTE - NCRS Discussion Boards
1966 CORVETTE
  • Bill Beasley
    1966 CORVETTE
    My VIN # located under the glove box has a 6 digit #. The owners manuel has a correct # of digits and matches the engine #. Is there another place on the car/frame that has the VIN # if so where?
    Thanks for your help,
    Bill
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1966 CORVETTE
    top side of frame above left rear wheel. mike
      Re: 1966 CORVETTE
      The starter is energized by the purple wire from the ignition switch, which goes through the fuse block and the inboard multiple connector below the master cylinder, and has another in-line connector in the area above the wiper motor before it gets to the starter. Check each of those connectors and terminals for corrosion or looseness to ensure continuity from the ignition switch to the terminal on the starter solenoid. If you have a Powerglide, also check the neutral safety switch for continuity/corrosion. If you haven't done it already, check and clean both ends of both battery cable connections.
        Re: 1966 CORVETTE
        Oops - this belongs under the next thread down
        • Tracy C.
          • July 31, 2003
          • 2739
          Youre in good company. #14 does this all the time *NM*
          • Mike M.
            • May 31, 1974
            • 8365
            Re: Youre in good company. #14 does this all the t
            hope mya don't pick your nose as much as ya pick on mikie.
            • Dick W.
              • 10483
              As you git older, yer options fer a having fun decrease. Pickin' on ya is one of the few left.
              Dick Whittington
              • Tracy C.
                • July 31, 2003
                • 2739
                I may be getting older, but a long ways from #14 *NM*
                • Dick W.
                  • 10483
                  Re: I may be getting older, but a long ways from #
                  It's scary, but the good Doc "Q" is only nine months older than I am. And I am older than dirt.
                  Dick Whittington
                  • Dick W.
                    • 10483
                    And you see what bored old hillbillies do for entertainment on Saturday night You have to put up with this drivel
                    Dick Whittington
