Got my engine going today for about 20 seconds or so. I had filled the floats with a syringe. However it looks like I was not getting gas from the fuel tank.
I was able to suck gas from the tank both before the fuel pump and then at the carb inlet. With the coil wire off I could not get gas to come out at the fuel inlet when turning over the engine.
The pump is a rebuilt unit from Corvette Central and this is the first time I have tried it. Is there a possiblity that the pump is installed wrong on the engine and what could I have done wrong? Or is it the pump and I have to rebuild or get it replaced? Or is it something else I am not aware of?
I do have the old incorrect pump which did work years ago but before I go thru the hassle of swapping wanted to get your opinions.
Thanks, Chris
Thanks, Chris
