C1 Heater Blower Motor - NCRS Discussion Boards
  • Bob Malone
    Does anyone have any suggestions on where to get a '60 heater blower motor rebuilt/restored?
  • Ed Jennings
    Re: C1 Heater Blower Motor
    Have you tried an auto electric shop? If they can get the motor apart and back together,(that is if the case will come apart) they can fix it. I can't remember off-hand how those motors are assembled. Might be worth checking out.
    • Bob Malone
      I've called several places in Dallas. I would have thought any electric motor repair facility could handle this but what I get is that they all work on larger or smaller devices. Since it's about the same size as an electric fan motor, I'll try small appliance repair shops next. It doesn't need rewinding, just bushings and a new lead wire. I'll do the case restoration myself.
      • Christopher R.
        • March 31, 1975
        • 1599
        I seem to remember that there was one on Ebay very recently. Advertised as NOS, NIB. I also remember that the price was low - ~$40. That usually means that the part is still available - either from GM or widely reproduced. FWIW.
        Any electric motor can be repaired. Usually all they need are brushes. Bearings sometimes. Most electric motor repair shops can make brushes and bearings. Of course, custom work is expensive.
        • Bob Malone
          Thanks Chris. I bought a replacement from Eckler's and it isn't close to being right without modifications. I then called GM Restoration Parts who did have them listed. When I asked about them, they told me they get them from Eckler's too, so it would end up being the same item. Chicago Corvette told me that they have them but that the Eckler's part is closer than what they offer for the older models.
          This is a simple task that is becoming a lot more difficult than it should be.
          • Ed Jennings
            Have you tried an auto electric repair (generator) shop? I would think that would be right up their alley.
            • Ed Jennings
              Bob, in terms of a replacement, you might try J. C. Whitney. I haven't looked at one of their catalogs in a long time, but they used to carry a lot of this type of stuff for older cars. There is also the junkyard route, as I think most GM cars of the period used similar motors, but in a lot of areas older cars are getting hard to find.
              • Christopher R.
                • March 31, 1975
                • 1599
                You, of course, realize that the part cannot be seen and is not judged.
                • Bob Malone
                  I'm not concerned about judging, only about installing something without the need to modify it to make it fit. Seems the easiest and cheapest way to do this is by fixing the old one.
                  • Joe Fisher
                    I just redid my motor on my 61. I own an autoparts store and ordered a replacement motor from AC Delco, Four Seasons, Everco and Siemens, none of which where even close. I didn't want to rebuilt mine because my car was in a flood in the summer of 99 in NJ. When I took off the motor, water and rust came out of it. But with a little time, and some patience, I got it work perfectly, and it is an original.
                    • Bob Malone
                      You just made up my mind for me Joe, I'm gonna rebuild mine too. The one I got from Eckler's is a four seasons. Thanks,
                      Bob
