C1 Rear Main Seal - NCRS Discussion Boards
C1 Rear Main Seal
  • Bob Herman
    C1 Rear Main Seal
    I'm attempting to correct a rear engine oil leak in my '58 which has a NOM 283 with a '57 casting date. The engine has less than 1,000 mi. on it since rebuild. It had a rope type rear main seal which leaked immediately after the rebuild. At least it appears that the seal is the culprit (the pan gasket could have been a contributor).
    I dropped the pan last night and ATTEMPTED to replace the rope seal with a neoprene seal. It appears that the rear main cap and the block are only set up for a rope seal. The seal channel has a "V" shape to it which the neoprene seal will not fit. I was under the impression that the neoprene seal was an alternative for this engine. Do I have the wrong seal? Am I stuck with a rope seal again? If the latter, will I need to drop the crank to install? The engine is in the car, but on a four post lift. Thanks for any help.
    Bob Herman
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C1 Rear Main Seal
    gary pronesti has a neoprene seal to replace the rope seal. put one in my early small block years ago and no leaks. hia new Phone # is 352 253 1957(he relocated to flordia recently) mike
    • Roy B.
      • February 1, 1975
      • 7044
      I installed the new rubber seal and it's still lecking a vary little. There is a tool you can get to replace the rope seal , after all it worked , just need to know how to replace it properly . I think I'll go back to it.
      • Bob Herman
        Thanks Mike and Roy!
        Roy,
        What was your source for the seal? Were you replacing it on an early engine with the "V" shaped seal channel? Thanks.
        Bob
          Re: Thanks Mike and Roy!
          Paragon has the correct alternative wire-reinforced neoprene seal to replace the "rope" seal, their #4340K, $25.00. I used one six years ago when I rebuilt my '57, never leaked a drop. Can't remember the manufacturer, but it's one of the well-known seal/gasket outfits - NAPA probably has it (or can order it).
          • Dave Suesz
            I put one in my 55 years ago...
            and it is holding up just fine..
            • Roy B.
              • February 1, 1975
              • 7044
              In my 265 V8 , got it from C@C.
