58/62 headlight buckets - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2918
    I need some help in identifying original Corvette buckets. Do originals have any stampings on them???? Are lefts and rights the same ??? Is there a screw on the back for a ground even though the AIM doesn't show a ground??? Are Corvette buckets the same as passenger car ??? Is the hole for the wiring grommet a special size ??? Any help is appreciated.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 58/62 headlight buckets
    pass car utilizes a larger grommet than the vet counterpart. mike
    • Mike E.
      • February 28, 1975
      • 5134
      Lefts and rights are identical, except toward the upper center,there is a small peg on the back side the indexes with a hole in the body. The peg has a small L or R on the end, indicating which bucket it is. It should NOT have a ground wire on it--that's passenger car.
      • Dave S.
        • August 31, 1992
        • 2918
        The buckets in question have the small hole w/ the L and R studs as Mike describes. They also have a 29 stamped on the back (about 5/8" high) and a GUIDE, Made in USA stamping w/ the GUIDE in script. Do the stampings sound correct.?????
        • Mike M.
          • May 31, 1974
          • 8365
          yes. mike
          • Dave S.
            • August 31, 1992
            • 2918
            Thanks guys *NM*
