C1: Diagnostic needed for my 1961 - NCRS Discussion Boards
  • Barbara S.
    • April 30, 1981
    • 599
    Today, when I started from a dead stop in my 4 speed '61, I heard a loud pop around the right rear wheel area. I don't hear it when shifting to 2nd, 3rd or 4th. It happended just about every time I started off in 1st gear. It is only when I start from a dead stop in 1st. I drained the rear end but no metal on the plug, but there is some fluid coming from the inner right rear wheel.
    Any thoughts what it might be?
    Thanks.
    Tony in Parkville, Missouri
  • Dave F.
    • December 1, 2003
    • 508
    Re: C1: Diagnostic needed for my 1961
    Sounds like you may have a trashed wheel bearing. Do you feel any heat around the hub? Have you jacked it up and checked for play?
    • Barbara S.
      • April 30, 1981
      • 599
      yeah, there's alot of heat on the wheel. Actually, both rear wheels felt super hot, but the noise was only coming from the right rear wheel...
      Haven't checked for play yet.
      Wheel bearing is your best estimate?
      Thanks.
      Tony
      • Dave F.
        • December 1, 2003
        • 508
        Might be brake related, as you will get a lot of heat with a problem there too. I'd ferret it out before I'd drive it much more, just for safety's sake. Good luck!
        • Barbara S.
          • April 30, 1981
          • 599
          thanks Dave. I've grounded it until further notice.
          Tony
          • Roy B.
            • February 1, 1975
            • 7044
            You brake shoe may be sticking or worn.
            • Barbara S.
              • April 30, 1981
              • 599
              I've noticed that my brakes have been a little spoungy. Maybe that would explain why both rear wheels were super hot. I'll check it out tomorrow.
              Thanks for the input. It is appreciated!
              Tony
              • Dennis C.
                NCRS Past Judging Chairman
                • January 1, 1984
                • 2409
                Yeah, I'd lose about 10 clicks on the rear brake shoes and go for a ride. DC
                • Allen W.
                  • September 30, 2000
                  • 106
                  You could have a leaking a brake cylinder. The shoes can get coated and really cause havoc. Irregular braking to the point of causing real chassis upset when braking. I would pull that brake drum before going anywhere. Just my 2cents.
                  Allen
                  • Rod Wagner
                    And it only happens in first because you are probably just starting from a dead stop after applying the brakes...
                    • Barbara S.
                      • April 30, 1981
                      • 599
                      Thanks fellas. I appreciate all the good input. My 61 is grounded until further notice!
