C3 water leak and vacuum feedback - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 water leak and vacuum feedback
    Tony Check the vacumn system for leaks or hoses not hooked up right. If you can raise the headlights after the car is shut off two minutes your system is pretty good. This should be your goal. Lyle
    Lyle
    • Tony Roussos
      Hi Lyle.
      Two minutes huh? OK. Now I have something quantitative to work with.
      Thank you.
      Tony
        • 11608
        #18
        In addition, it could be one leak or (more likely) several leaks that are hurting you here.
        Buy the vacuum troubleshooting manuals (one from NCRS, one from Dr. Rebuild) and go through the system. You'll then realize that you're not getting a lot of answers on the vacuum question because there are, well, at least 10 "correct" answers and possibilities.
        Good luck,
        Patrick
        • Tony Roussos
          #19
          Fair enough. I'll get at least one if not both of those books. Thanks Patrick.
          Tony
          • Dick W.
            • 10483
            #20
            I believe that there are several good articles in the NCRS Restorer magazine. I believe that the late John Woods did an in-depth article on trouble shooting
            Dick Whittington
            • Tony Roussos
              #21
              Any particular article? Which issue (s)?
              Thank you.
              Tony
              • Harmon C.
                • August 31, 1994
                • 3228
                #22
                Tony Leaks are hard to find with no storage of vacuum after you shut off the engine the leak quits as the vacuum is gone and while it is running you can't hear the leak. A long clear plastic hose from a running car outsde can provide vacuum to your Corvette while it is not running so you can hear the leak. I find that the relays leak on many systems. Lyle
                Lyle
                • Tony Roussos
                  #23
                  Hey. That's a real great tip, Lyle. I'm definately going to use that one.
                  Is hose length a factor? What is the maximum length I should use before loading down the supply vehicle occurs, if at all?
                  Tony
                  • Harmon C.
                    • August 31, 1994
                    • 3228
                    #24
                    Tony I think 25 feet should be enough and just use the small clear plastic tube from the hardware. Their should be no load on the supply vehicle as your Corvette runs with vacuum leaks. Lyle
                    Lyle
                    • Roger S.
                      • May 31, 2003
                      • 262
                      #25
                      To solve my vaccum leaks I got a small vaccum pump. Connected it the hose that was connected to the engine vaccum source. Then I disconnected each vaccum hose one at a time. When the vaccum went up I then knew I had isolated the leaking component. I had a couple of hoses that were bad, but the big leak was at the metal housing check valve/splitter. Where the two sections were put together was a large air leak.
                      Roger
