The performance verification test guide book says that the oil pressure should be mid range after warm up. My gauge was checked and should be accurate. I have a melling M55 series pump in the engine. The readings are high compared to what the guide says. 60lbs or more when you step on it. In order to pass the performance verication you need 100% and this will not pass. Anyone have a sugestions on a oil pump that will give me correct readings. Should I go with a stock GM pump? Is it still avaiable? Or should I leave the pump and recalibrate the gauge so it looks like the readings are correct. I'm not sure if this is even possible.
Mike
Mike
