C1 dim headlamps - NCRS Discussion Boards
C1 dim headlamps
  • Chris H.
    • April 30, 1990
    • 817
    C1 dim headlamps
    My 62 has been sitting for 5 years and I just finished a front engine/underhood restoration.
    My LH headlamp has full brightness but the inner LH and the two RH ones are dim. In looking at the wiring diagram it looks like they all share grounds. What should I look for or should I just order a set of Lectric Limited lights? Mine are a mish mash of headlamps (one T3 though). I thought they all worked when I parked it in the coney Island.
  • Joe Maulsby
    Re: C1 dim headlamps
    Be sure you have good clean connnections between the wiring harness plugs and the back of the bulbs. Double check your ground wire connections. Old bulbs will also burn with less intensity than newer bulbs.
    • Chuck L.
      • July 31, 1996
      • 260
      Chris, this is a common problem with the harness plugs. I had it myself and there are numerous prior posts on hw to correct the problem.
      Chuck Lyman
      Kansas City Chapter
