I Can't Find or Know What To Call This... - NCRS Discussion Boards
  • Randy Adams
    I have a '64 327/300 w/Carter AFB. I'm looking for a PCV valve. The shop manual calls it a "fixed metered orfice". The drawing of it looks like a block with a hose fitting on it. I have a pvc valve on mine but that can't be correct. My local GM dealer said the part #6421934 was for '63-'64 and is no longer available and has no superseeding number. I find no such animal anywhere I look. Any help would be greatly appreciated.
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: I Can't Find or Know What To Call This...
    Randy,
    Try Paragon for the metered orifice as I believe this part took the place of the PCV valve in 1964 and 65. The 1963 vette had a PVC valve and is a different configuration than the 64 and 65. If you have a Paragon catalog there might be a picture of what you are looking for. Tim
    • David Z.
      • April 1, 2002
      • 181
      Randy
      Paragon has it: Part #1061
      http://www.corvette-paragon.com/cata...7-BE4677502CDA
      Hose runs from the oil filler tube to the fitting at the rear of the carb.
      Dave Z
      Dave Zuberer
      • Randy Adams
        Thanks Tim, Paragon has it. (Vacuum Restrictor Elbow)
        • Randy Adams
          Thanks Dave, it all comes together at the same time.
          • Mark H.
            • July 31, 1998
            • 384
            Note that the elbowed metered orifice fitting does not screw directly into the back of the carb. There is a fitting in between them, essentially a spacer, that moves the elbow off the carb enough to permit the hose to attach w/o interference. Paragon has the spacer as well, or you can make one with a brass nipple and coupling (cut the nipple down a bit so it's not too long if you have to).
