cleaning underside of body - NCRS Discussion Boards
  • Michael F.
    • 745
    what is the best way to clean the underside of the body (fiberglass)> I have frame looking good but how to make underbody look new again(or close to it) Any ideas would be appreciated as this is an unrestored underbody with restored frame.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • alan drake
    Re: cleaning underside of body
    I've used Brake Parts Cleaner! Buy at Wal Mart for $2 and get 1/2 dozen cans.
    Do not know if this is the best way for a NCRS style can, but it sure works well. I have found no effect on the fiberglass. Will be interested to see if other owners think I made an error since there are lots on pro's at the site. Good Luck and make sure you have lots of ventilation, I did mine on a lift with fan running.
    • `Michael Southard
      I don't know... I'm waiting for some one to chime in on your question as I'll be doing the same thing in the next month or so.
      I was considering pressure washing with my lowest pressure nozzle, but as look closer, I may only need a wash cloth and some soap.
      • Dave McDufford
        I used full strength liquid Spic & Span with a scotch bright pad and rags, and then hosed it off. It seemed to work OK.
        Dave
        • Jon S.
          • November 1, 1992
          • 202
          Michael, a local body man uses a product called Prepall with great success. Hope I spelled it right. Wipe on and wipe off.
          Best regards, Jon
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            I spray with degreaser, let it soak for a while, then use my pressure washer hooked to hot water. The closer the nozzle is to the glass, the better it does. Have never experienced any damage. Use eye protection for sure and don't try to remain beautiful during the process. Best, Dennis
