I'm trying to get my radio functioning, it came down to the antenna lead. I ordered a new one just plugged it in without installing it and it did the trick. Now when I tried disassembling the old one I had to tear it apart leaving the silver collar corroded into the base itself. I will look for a used base at my local junk yard.
Looking at the new lead and old one it would seem that the only part that went bad is the connector at the antenna base. I do a lot of cable splicing in my job and was wondering if someone sells the connector by itself. Or a male and female radio side connector so I could use the original cable and the new connector put together with a male female connection. The reason I ask I understand it very hard to pull a new lead through the old ones path without tearing up original carpet, I won't do that. Any leads on these connectors would be appreciated. I will also visit the junkyard and experiment with examples from other GM cars to see if I can use parts from an original set up to accomplish the above.
Kevin
Kevin
