C1 Front Cross Member - NCRS Discussion Boards
  • Daniel S.
    • 16
    Does anyone know if the underneath where the two holes are on the cross member---is it tapered to the holes or is it flat?
    Dan
  • Patrick T.
    • September 30, 1999
    • 1286
    Re: C1 Front Cross Member
    The two drain holes are tapered, at least on a '57. PT
    • Daniel S.
      • 16
      I have a 59.
      thanks dan
      • Justin B.
        • March 1, 1996
        • 478
        I have a 58' and a 60'....both are tapered.
        • Mike M.
          • May 31, 1974
          • 8365
          dan , pat and justin: think the drain holes you guys are referring to are in fact access holes for the 49 to 52 chevy pass car 6 cyl engine mounts.you'll recall the 53 to 62 vettes used a front X-member common to the 49 to 54 chevy pass cars. mike
          • Patrick T.
            • 1286
            Mike, the drain holes I am referring to are tapered funnels, like in a measuring cup. I believe there are also threaded holes directly above, on the top of the crossmember as well. PT
            • Justin B.
              • March 1, 1996
              • 478
              I may be confused with the original question but I an referring to the two holes on the underneath side of the crossmember..the two facing the road. They are not flat holes but tapered out towards the bottom of the car or road. Hey Mike, did the LT5 win the "Willys" coice award?
              • Mike M.
                • May 31, 1974
                • 8365
                Willy likes his new drivetrain.can't wait to get him in the Porsche chase. mike
