I',rewiring my engine compartment and have a pretty simple question if someone has the time to pop their hood they can answer or a set of better prints.
On my horn relay assy, I marked the wires that slide onto the spades under the relay grn and blk, but the two large wires I didn't and my print doesn't show me a exactly where the large solid RED wire goes (I'm supposing to the Batt-Conn) since it is stamped BATT. on that part of the relay
The other large RED wire is connected/attached (sealed in rubber boot) to a black wire of about a #10/12 that has the proper attaching connection for the relay also. Does that one go on the other side of the battery wire?
Thanks,grr#33570
Thanks,grr#33570
