I have not been able to find the exact dimensions of the " Power Top Switch KEYHOLE cutout" that is behind the courtesy light. My seems to be void of this cutout. Does a template exist or does an old GM blueprint show where the cutout is die cut? I crawled under a few real nice '61 dashboards at Carlisle this year(with owner's permission of course) and tried to estimate the size of the circular cutout and the Width/Length of the notch etc. It's only worth a few more points, but each one helps! Thanks, Bruce #39024.
61 instrument panel cutout
Re: 61 instrument panel cutout
Bruce...
You might want to look & feel again...Unless someone glassed over the cutout "Keyhole", it should still be there. It is directly behind the coutesy light. If the radio is out, you can locate it from inside/under the dash. On a few survivor cars, I have seen the cutout hole open without a power top...- Top
