Correct parts color - NCRS Discussion Boards
Correct parts color
  • Larry Lena
    Correct parts color
    What is the correct color of the washer tank bracket and bracket for the expansion tank on the inner fenders for a '68. And also the body mount bracket #1 on the body?
  • Dave F.
    • December 1, 2003
    • 508
    Re: Correct parts color
    I believe the tank brackets are semi-gloss black, but I'm notsure about the body mount bracket. I have the same need to know, and will research this further. I'll post my findings asap.
    • Chuck S.
      • April 1, 1992
      • 4668
      Larry, the No. 1 body mount bracket was dip-painted semi-gloss black; the heads of the rivets attaching the bracket to the body should be natural aluminum since the bracket was installed already painted.
      I am unfamiliar with the 68 expansion tank bracket, so I can't give you a definite answer on that question. I could make a semi-educated guess, but I'll wait to hear the correct answer.
      • Dave F.
        • December 1, 2003
        • 508
        Larry,
        I just went through the TIM&JG and could find nothing on the finish for either bracket, only verbage on the tanks themselves. Hopefully someone out there knows of another source for this information.
        Dave
          Larry------
          All three brackets, coolant supply tank bracket, washer fluid resevoir bracket, and body mount bracket, were dip-painted semi-gloss black.
          • Larry Lena
            Thanks guys semi=black it will be, makes make life a little easier.
