I have a problem with the turn signals on my 68. I have been trying to figure out this problem for a while now and the time to drive my car in MN is running out, so I figured I would see if you guys had any ideas. The signals do not work left or right. They had been working fine after I replaced the flasher. The hazard lights do work properly accept if you press the brake pedal then the light stay on. Also the tail lamp fuse burns out if I put the headlights on, but I checked and the fuse also burns out if I pull the knob out only half way (just running lights). Any suggestions would be greatly appreciated,
Gary
Gary
