Members,
I'm having an issue associated with installing front shocks on my '65.
The lower shock mounting bolt (5/16-18) feels soft when I approach the final torque setting. I'm concerned that the threads in the nut that is welded to the lower control arm are partially stripped.
Does anyone have a suggestion on how to solve this problem without disassembling the front end and having a new nut welded into the lower control arm?
Thanks in advance for all ideas.
Gene
Gene
