Battery Restoration - NCRS Discussion Boards
Battery Restoration
  • Larry E.
    • 1652
    Battery Restoration
    Hello:
    I have an old R59S Battery with the correct codes for a 1968 Corvette. It will
    not take a charge no more. Acid has been drained and baking soda added to neu-
    triliaze the residue. I have heard of people cutting open battery and disposing
    of the insides and installing a "heavy duty" motorcycle battery inside the bare case just for judging purposes. Has any body ever done this? What is the procedure?
    Thanks; Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Joe R.
    • July 31, 1976
    • 4547
    Re: Battery Restoration
    Larry,
    There is no procedure as the case is plastic and heat sealed. Call Restoration Battery and order you a new battery. Phone 1 513 451-1038. They advertise in the Driveline.
    JR
    • Harmon C.
      • August 31, 1994
      • 3228
      Larry Some shark owners with a battery that is not reproduced have cut the bottom out where the judges can't see and made a hook up inside to a small battery for judging. If you are crafty you can make it work but you won't be the first. I have seen two that were proud of their work after judging was over. Lyle
      Lyle
