C 1 Seat Track Restoration - NCRS Discussion Boards
  • David Lyon
    Can anyone help me locate a person who restores seat tracks for C1's? My car is a '58. I need the levers re-chromed, new rollers installed and metal housing and mount brackets re-furbished. As always, thanks in advanced.
    Dsvid
  • Larry P.
    • June 30, 1999
    • 481
    Re: C 1 Seat Track Restoration
    David,
    You can do these yourself. I did mine and they work great. There are eight rollers with a carrier assembly that has ball bearings. After you disasemble them you will be able to determine how many of each you will need.
    If the carriers are good you can cut tube stock to make the rollers. I think they are 1 1/4 diameter by 1/2 wide. You need to grind bevels on the edge so they roll in the track. If you need the entire assembly they are about $37.00 bucks apiece! You need to grind any/all corrosion out of the track where they roll. If you decide to do them yourself, Email me and i will find my notes.
    Larry
    • Dennis A.
      • April 30, 1999
      • 1010
      David..
      Paragon does a good job...(a little on the $$$ side however)
      • David Lyon
        Re: C 1 Seat Track Thanks Larry & Dennis *NM*
