Master cylinder paint - NCRS Discussion Boards
  • Matt Kunkle
    Does anyone make a paint that is resistant to brake fluid? My engine compartment is now fully detailed, except for the master cylinder.
    Matt
    Re: Master cylinder paint
    Matt------
    An epoxy paint is about as chemically resistant as you'll be able to get. VHT brake caliper paint also has some chemically resistant properties. Basically, though, just about any paint may be affected by long-term contact with glycol-based brake fluid. So, you need to be sure that any spillage is wiped up and cleaned up with water as quickly as possible.
