71-74 454 Timing Covers - NCRS Discussion Boards
    Anyone out there with a 71-74 big block who is reasonably sure that their engine and the timing cover are original? You don't need to be absolutely positive, just reasonably sure. If so, could you please look at it and see if your timing tab (pointer) is spot welded to the timing cover OR it it's a seperate pointer attached by 2 of the timing cover bolts? This is really easy to discern; just a glance will do it. Also, it doesn't really matter if it's a Corvette, or not. In this regard, any 71-74 Chevrolet with 454 and an original engine and timing cover will be useful information.
  • Joe Maldino
    Re: 71-74 454 Timing Covers
    I have a 402 from a 72 pickup and it has the two bolt tab.
    • Michael F.
      • 745
      Joe, go to corvetteforum.com and then to c3 board if no one respones, Zwede has an original 71 454 he can tell you if nobody here does.
      Michael
      70 Mulsanne Blue LT-1
      03 Electron Blue Z06
      • Warren F.
        • December 1, 1987
        • 1516
        Joe:
        The timing tab on my '71 LS-6 engine is attached with 2 bolts. Degree markings on the face are 4 0 4 8 12 16.
        • Bernard S.
          • June 30, 1992
          • 56
          Hi Joe:
          71 LS6 Auto two bolts. 72 LS5 Auto two bolts. Both car March built.
          • terry westrick
            My 73 tab is spot welded. Should be orginal, had the car since 9,600 miles.
