Need headlight switch - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    I need a headlight switch for my 72. None of the local parts stores carry this switch, and it is discontinued from the dealer. Any thoughts on where I can get a new headlight switch (repo is OK)?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Need headlight switch
    Ed you might try www.lectriclimited.com and any of the Corvette parts catalog parts places like The Last Detail, Dr. Rebuild,etc.
      Ed-----
      The switch is reproduced from the original tooling and is identical to the GM piece. However, it is identical to the LAST AVAILABLE GM piece, GM #1995191. The original switch used for your car was GM #1995166. There are some slight configuration differences between the switches, but the 1995191 is an improved switch and it will work perfectly for you. Plus, no one will ever see it.
