Put different rims/tires on my 70. Dispite the fact I need to space a little, I noticed a problem. The driver side tire turns stop to stop no problem. The passenger tire outboard edge rubs the lower rear of the body wheel well at the flare when I turn right. It may also rub slightly at the right front lower well when I turn left.Could this be a suspension issue? Or a body issue? How do I check for either?
Putting the stock set back till I figure it out.
