What are the correct numbers/markings for a 63-64 corvette standard master cylinder? The reference that I have does not include master cylinders. Thanks.
63-64 Master cylinder identification
Re: 63-64 Master cylinder identification
Dave,
63 master cylinder is casting number 5462389 with a thumbscrew lid. the 64 is casting number 5464264 with a bail wire lid.
Both have a 7/8 bore.
While we are on the topic, I have the prettiest unrestored 63 casting I've ever seen for my July build 63, but the casting number preceedes my car's build date by about 9 months (Oct 62). I know the "approved window" is about 6 months.
How big of a point hit is this? Should I be looking for someone to trade with?
thanks,
tc- Top
Dave, if it is a 63 that you are looking for, a power brake car has a few differences on the master cylinder. At first the power brake cars had master cylinders with the thump screw. The thumb screw sat too high as a result of the power booster and the thump screw was hitting the underside of the hood. Therefore, most power brake cars have a hex head bolt/screw to tighten down the master cylinder cap.
Also, there is an extra bleeder outlet on a 63 power brake master cylinder. It is located on the master cylinder, forward towards the front of the car, engine side.
Harry
38513- Top
Thanks for the numbers. The project car I have is a 63 but it has the bail type lid on it. Does the 64 cylinder have delco or any other name on them. I trying to determine if the cylinder I have on the car is an original or reproduction. Thanks- Top
TC, Have you ever actually seen a '64 master cylinder with that date code format? Take a look in the archives at previous discussion on this board on this topic. Some folks believe the TIM&JG is incorrect and they were actually Julian dated.- Top
