C-2 Spare Tire Tub removal - NCRS Discussion Boards
  • Ken Harants
    Need directions on how to remove the spare tire tub. I can see there are four bolts inside the tub. Do the 2 hinge bolts also have to be remove and if so how? Thanks in advance for your help.
  • William C.
    • May 31, 1975
    • 6037
    Re: C-2 Spare Tire Tub removal
    The two hinge bolts must also come out, there is a flat on two sides that a wrench will engage and they just screw out.
    Bill Clupper #618
    • Donald O.
      • May 31, 1990
      • 1580
      You also need to remove the two bolts holding the lock bolt through the tub and up top the rear cross brace.
      Don
