53, 54 Hardtop, PLASTICON??? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    I have purchased, with some other parts, what I believe is a 53 to 55 hardtop. How can I identify it, is it gm? If someone truly needs it for themself, please contact me.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 53, 54 Hardtop, PLASTICON???
    This is the plasticon top on my 55 ( big back window) Scotch top has a small window and then there was the bubble top , which I also have..You see the two tops on E-bay Quit often.
    • William B.
      • April 30, 1975
      • 939
      Thanks Roy, That looks like what I have, it has different looking latches inside and the weatherstrips are missing. I will check tonight if it has a rain gutter, I don't think it does.
      • Chuck G.
        • May 31, 1982
        • 2029
        To add to what Roy has said, there are/were no "factory" hardtops from 53 to 55, only aftermarket. Roy's is a Plasticon, the other common fiberglass top is Scott. Then there are the clear and/or green tint "bubble" top, made, I believe by Bell. Chuck
        • William B.
          • April 30, 1975
          • 939
          Thanks Chuck, I guess its between a plasticon and a scotch. I am leaving now for my barn And I'll be able to check the top.
          • William B.
            • April 30, 1975
            • 939
            My top looks just like Roy's. But on the side behind the window glass on each side there is a button(?) covering the screw for the latch, is this correct?
            • Roy B.
              • February 1, 1975
              • 7044
              No it was only their LOGO on the button
