fuel supply - NCRS Discussion Boards
fuel supply
  • David J.
    • April 30, 2004
    • 99
    fuel supply
    Hi Everybody !
    The inside of my fuel supply line that runs through the right frame rail from rear to front is rusted internally. My question is can the line be replaced with the body on ? Help!
  • Dennis A.
    • April 30, 1999
    • 1010
    Year of Car is? *NM*
    • David J.
      • April 30, 2004
      • 99
      Re: Year of Car is?
      Hello Dennis
      The year is 1966 big block coupe.
      David
      • Chuck R.
        • April 30, 1999
        • 1434
        Re: fuel supply
        Hi Dave,
        I'm a C-3 guy but if your C-2 is anything like my 68, it would be a bear!
        If you follow your hand along the kickup frame rails, you should be able to feel out the heads of the clip bolts to first decide if you can swing a wrench to back them out.
        Second, as you mentioned, the act of pulling the old lines out and re-installing new lines through the frame rail would take some serious finessing. I think that most prior discussions regarded possibly raising the body off the frame on the passenger's side enough to give adequate clearances to get at both the bolts and lines.
        The higher the entire car is safely off the floor is a plus too.
        Like I said, I'm a C-3 Dude, what do I know about 66's
        Chuck
        • David J.
          • April 30, 2004
          • 99
          Re: fuel supply
          Hi Chuck!
          Thanks for your input. I was hoping that some one might have tried this with sucess. I was also thinking that I could remove the lower panel below the rear bumper and that would give me the room I needed or I was thinking I could remove both tail lights on the right rear and maybe fish it in and out through the tail light opening. Any way thanks for the help.
          David
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: fuel supply
            If your looking at the one piece pre-bent lines, it will be a challenge no matter where you feed the lines from.
            Hope you get better informed responses.
            Be safe,
            Chuck
            • Rick Miller
              Re: fuel supply
              In the Richard Newton 1963-1967 Corvette Restoration Guide on page 80 it says, in part, 'In order to replace the steel fuel line on the right-hand frame rail, you'll have to separate the body from the frame.' I can't say whether this is correct or whether there is a trick that invalidates the statement. Hopefully someone with some experience will post. FWIW, and good luck.
              • David J.
                • April 30, 2004
                • 99
                Re: fuel supply
                Thanks Rick. I was afraid of that responce.
                • Ronnie Robertson # 36786
                  Been There- Done That
                  Check the archives for details
