Started the electrical testing on my 66 roadster body off project. All new harnesses and mostly refurbished components. Installed a 30 amp fusible link across the cutoff switch at the battery positive terminal. Everything works except the right turn signal and panel lights. When turn signal switch turned to right, horn blows. I suspect an incorrectly installed wire at the steering column harness plug. Had this apart to disassemble the column. Turned rheostat on the light switch both ways, turned on headlights but still no cluster or dash lights. Installed a new 4 amp fuse but to no avail. Clock, radio, blower motor all work but no lights. Could this still be a faulty ground and if so where? Since I have clock etc., I thought they used the same ground as cluster lights. High beam light works and left turn signal and light works.
Dave Kitch
33108
Dave Kitch
33108
