Suddenly the courtesy lights and clock have stopped running in my 64 convertible. I immediately assumed the fuse was blown. When I checked it, the fuse looked O.K. but I decided to change it anyway.
The current fuse is a 30 amp. When I went to the owner's manual it showed a 5 amp (I think) should be in the Courtesy slot. A parts catalog I looked at showed a 20 amp fuse.
I used a 20 amp fuse I had in the shop last night but immediately blew it when I installed.
Any idea what fuse should go there? If it continues to blow, where would the likely source be? An article in the archives mentioned the door switches as likely culprits.
Thanks again for any and all help. Y'all are the greatest!
Chris Rose
Memphis, TN
Chris Rose
Memphis, TN
