I am still having a hard start problem. It is a problem after the car sits for just a day or overnight. It is a 350 with a brand new out of the box q-jet carb. The problem started after I installed the new carb.I have checked for Vacuum leaks, replaced the mounting gasket, checked the choke over several times,everything is o.k. Now if I pour a little gas down the throat of the carb it pops right off.After asking around several people have said the well plugs in the carb are leaking.Would this be likely on a brand new carb? And if so what is the best fix. I've had a couple guy's tell me to pull the carb and put some J-B weld over the well plugs. Is this an acceptible fix to the problem?Thanks in advance.
Tom Stanton #41491
Tom Stanton #41491
