C1 Transmission? - NCRS Discussion Boards
C1 Transmission?
  • David Lyon
    C1 Transmission?
    My car is a "58 with a transmission with a tag 3915077. It has a 3884655 GM casting number at the top of the cover the driver's side. The speedo cable connects on the passenger side. Any idea what this transmission is - truck? Thanks in advance.
    David
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 Transmission?
    65-up Muncie four speed sounds like.
    Bill Clupper #618
    • David Lyon
      Bill,
      Is this a Corvette application? Appreciate you quick response!
      David
      • William C.
        • May 31, 1975
        • 6037
        Used in Corvette and passenger cars. Aluminum case and tailhousing. Should have a number cast into the main case on the pass side, ending in 325, 010, 660 or 661 depending on the year.
        Bill Clupper #618
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          Bill has forgotten more than I'll ever know, but..
          ...I don't believe '58 Corvettes w/ 3 or 4 speed ever had the speedo drive ever enter from the RH (passenger) side. Best, Dennis
          • William C.
            • May 31, 1975
            • 6037
            Re: Bill has forgotten more than I'll ever know, b
            That's why it's a Muncie, not a T-10
            Bill Clupper #618
            • David Lyon
              Thanks to You both for the Input *NM*
