I received one of Don's wiring diagrams for my 1968 it is great but now I'm really confused. I ordered what I thought was the correct relay GM part number 7729602. That relay has terminals in the pattern of one by itself (A) then the other two in a T shape (B) & (F) pattern. Dons diagram shows one above the other two. If the relay that I have is OK which terminal do I attach the wire from the circuit breaker to (A) (B) or (F)? Also which is right relay? Don's diagram shows a circuit breaker which I was not aware that I needed. Where is the circuit breaker mounted?
I guess the most confusing problem I have is I attach the hot wire to Terminal A (on the relay that I have) and then attach a probe to either of the other two terminals shows no power running to them. I though that the relay would have current going in one terminal and out another.
Dons diagram shows a 14 brown wire going to a radio capacitor. Is that just ended there and were is it mounted?
