I am following Clem's advice to replace the valves in our 40K mile 396 engine. Purchased the spring set 12371061 from GM (it did come with the retainers and the plastic umbrella seals), the rubber valve stem seals 460527, the keepers 3947880 (they are not purple, the parts manager called and was told they have been trying to get that statement regarding purple out of the PP parts books for years but have been unsuccessful), the .015" thick hardened shims 3875916, and new rocker nuts 3896648.
Here is what I have completed so far:
marked the balancer in 90 degree increments,
have the engine located on #1 TDC preparing to replace the parts on #1 and #6,
then rotate the engine clockwise 90 degrees and complete #8 and #5,
then rotate the engine clockwise 90 degrees and complete #4 and #7,
then rotate the engine clockwise 90 degrees and complete #3 and #2.
Have the car in first gear with the parking brake on with the wheels chocked.
Have air supplied to the #1 cylinder through the spark plug hole (about 65 psig).
Removed #1 exhaust keepers (copper colored), the retainer and springs. I was expecting to find a .015" thick shim below the spring but found a .050". Put it back together and removed #1 intake parts, same .050" shim. Can someone tell me what is the correct thickness? Thank you
