'66 COUPE SAGGING HEADLINER - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Do I need to find a shop familiar with mid-year vettes to fix a sagging headliner? The material itself is in nice condition, so I'll assume it has been replaced previously.
  • Stephen P.
    • September 30, 2002
    • 116
    Re: '66 COUPE SAGGING HEADLINER
    There's quite a bit of information on this subject in the archives. I think that you will find the consensus is there is no good way to re-attach a sagging headliner. I tried unsuccessfully. Finally went with the Al Knoch headliner and am happy with the results. His headliner is a rigid plastic, so it's not the same as the original.
    • Dick W.
      • 10483
      Have tried all adhesives with absolutely no satisfaction. Once the foam starts to deteriorate it is all over. The only option is to replace it.
      Dick Whittington
      • John Fowler
        • Rob A.
          • December 1, 1991
          • 2126
          Although I've already ordered a new headliner, since the glue attacking the foam sounds like the problem, I was wondering if anyone has tried the type of adhesive that hobby shops sell for covering foam wing cores on model airplanes. It is specially made to not "eat" the foam.
