60 Vette Air cleaner on a holley or other carb - NCRS Discussion Boards
  • Dave #34924
    Is there a way to put a 60 Vette air cleaner or at least something close on a Holley or other aftermarket Hi-po carb
  • Verle R.
    • March 1, 1989
    • 1163
    Re: 60 Vette Air cleaner on a holley or other carb
    Dave,
    Holley inlet diameter is larger than your 60 carb.
    At a minimum you will have to look for a carb base that will fit the holley and match the 60 air cleaner top diameter.
    Verle
    • Christopher R.
      • March 31, 1975
      • 1599
      No and yes. Go over to the C1 section on the Corvette Forum where this is being discussed right now.
      I did this. Mated a junk EBay 3721 air horn (top) to a modern Edelbrock AFB (bottom). Voila! A carb that'll fit Holley intake bolt pattern manifolds and C1 air cleaners. Gas line and choke hooks right up too!
