Re: 1970 Gas Cap - Vented or Non-Vented
Patrick-----
There may have been some element of parts consolidation that played into this. However, if that were the only rationale, then why specify that for 63-67 models the tank should be used with the "sealed" cap? The tank with the integral pressure vacuum valve can be used with "vented" cap (late 1969's, including mine, came from the factory that way), so why specify that the cap be changed when the updated tank is used in SERVICE as a replacement?
Also, the fuel tank filler "boot" is described by GM as a SEAL. It is designed to "seal" against the bottom surface of the deck lid and around the filler neck. Fuel vapors which vent from the cap then have to escape from either the drain or the unsealed filler door opening. I'm sure that most vent through the filler door opening. For C3s, especially C3 convertibles, the air flow created by the "kammback" design causes these venting vapors to be carried into the passenger compartment. I believe that's one of the reasons why GM added the integral pressure/vacuum valve in late 1969 (the other reason was the upcoming EEC controls first used for 1970).
Patrick-----
