C2 BB engine codes - NCRS Discussion Boards
C2 BB engine codes
  • Brian H.
    Infrequent User
    • December 1, 1994
    • 18
    C2 BB engine codes
    Has anyone ever seen a BB engine block with an engine build code stamping and the vin derivative reversed in position.(outboard and inboard on the pad)
    The car that I saw it on is a '66 BB and the engine code is on the inboard side instead of the outboard of the pad. Of course as a result the VIN derivative is stamped on outboard side.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2 BB engine codes
    Tonowanda anomolies can occur. have seen what i believed was a "real" bb pad wherein the machine assembly data was rotated 180 degrees. as with all suspected anomolies, i'm suspicious of restamping and spend more time on such a pad than i would on a "typical" stamping. mike
    • Michael W.
      • April 1, 1997
      • 4290
      I thought I saw an example or two in Al Grenning's collection, could be wrong.
      • Brian H.
        Infrequent User
        • December 1, 1994
        • 18
        Thanks Mike & Mike *NM*
