66' 427/390 locking gas cap gasket - NCRS Discussion Boards
  • Jay Bunt
    Is the gasket/seal on the locking gas cap supposed to be the cork style or rubber? Any help is appreciated.
    Jay
  • Geoff C.
    • May 31, 1979
    • 1613
    Any cork would last about 1 complete turn *NM*
    • Jay Bunt
      Re: Any cork would last about 1 complete turn
      Geoffrey,
      Locking gas cap. No turns/twisting etc. Are you familiar with a locking gas cap?
      • Bill Lucia
        Re: 66' 427/390 locking gas cap gasket
        Jay: by coincidence my 66/427/390hp car came from the original owner with a locking gas cap. What is left of the gasket "APPEARS" to be either cork or brown paper. As you may know the locking gas cap was a dealer installed option and not a factory part. The original cap came with a brown paper gasket. I have both the original cap and the locking unit. The original cap with the paper gasket does not seal worth beans so I have two. One to drive with a rubber gasket and one to show with the paper. You might want to continue your search for gasket material because mine has only remnants left and its hard to tell but if I had to say I'd go with paper (could be glue remnants as well).
        Regards
        Bill #8620
        • Geoff C.
          • May 31, 1979
          • 1613
          Locking gas cap gasket
          Regarding cork: it provides a suitable liquid barrier when force is applied in the compression mode, however when force is applied torsionallly it tends to crumble badly.
          I seem to recall that it is still necessary to twist the locking gas caps to seat it properly. However, I cannot readily check my old cars. They are in a separate garage 100 foot from my house, and still somewhat snow bound. Call me lazy, but I have not ventured there for 2 months and when my 500-foot long driveway is plowed, they pile up the snow leading directly to those garages.
          • Bill Lucia
            How it works
            The locking gas cap that I have pushes onto the filler neck. The lock tabs (spring loaded) spread as the cap is pushed and snap under the rim of the filler neck. To release the cap the key is inserted and turned. This opens the lock tabs allowing the cap to be lifted off of the filler neck. The action of turning the key may inadvertently turn the cap but it is not necessary to do so to remove it. The open sections of the filler neck have a tab that keeps the lock tabs from slipping into the opening. On the standard cap you must depress the cap to get the tabs on the cap to clear the tabs on the filler neck. As you push down and turn the cap the cap tabs clear the filler neck tabs and it pulls itself down and seals the cap gasket against the filler neck. To remove you reverse the process, (i.e. push down and turn to get the tabs - both sets to clear each other). The locking cap uses the key to get the tabs to extricate themselves from the lip of the filler neck, thus, you don't need to turn the cap per se.
            regards
            Bill #8620
            • Jay Bunt
              Bill/Geoffrey,
              Thank you for you time and info. Geoffrey, you made me laugh. Let me know what you find out when you get through all of that snow!
              Regards, Jay
              • Warren S.
                • April 30, 1987
                • 100
                Re: How it works
                For what it is worth, I agree with Bill 100%. My dealer installed locking gas cap does not require any turning. My cap and key work exactly as Bill has described.
                • Geoff C.
                  • May 31, 1979
                  • 1613
                  • Jay Bunt
                    Re: Snow
                    Yes, I do.......Thanks again for the laughs...
                    • Bill Lucia
                      Sense of humor intact...smiling NM *NM*
