I'm replacing the weatherstripping on the doors and read that there was a change in the way the stripping was installed in the 58'. Evidently there were screws and brackets used originally but soon thereafter it was found that cement alone was a better solution. Would you agree that cement is enough? What kind of cement should I use? At the moment, all I'm replacing is the area on the door posts and then the stripping in the trunk.
Your thoughts are continually appreciated.
