Id a block challange - NCRS Discussion Boards
  • Jon #40768
    I was just given a 4 bolt main block I can not id. Can you all help? The casting is 397000. The date appears to be C2 8, however I am not yet positive. The pad is stamped C6Z124931 and V0315TXA. There is also a 21 cast into block next to the block casting number. Two screws and a 3 are also cast in the rear of the block. A daimond shape surrounded by an "N", a "D", and a "T" are also cast in the rear of the block. The following are cast into the timing cover and bell housing: 010, 020, H18, G25, 512, and 532.
    I am guessing that this is a 68, 78, 88, or 98 block.
    Thank you
    Jon
  • David D.
    • 330
    Re: Id a block challange
    Jon, TXA code is for a 350 4 Barrel from a 1975-1977 Chevy/GMC 20-30 series pickup. Dave
      • 15573
      Cylinder case casting number is most likely 3970010. 350 CID unless it has been bored. A ubiquitous small block number.
      • Jon #40768
        Thank you, Jon *NM*
          Re: Thank you, Jon
          It's out of a '76 Chevy pickup built at Fremont, California.
          • Tracy C.
            • July 31, 2003
            • 2739
            yes but what color was the donor truck painted?
            you guys amaze me..
              Re: yes but what color was the donor truck painted
              Everything that came out of Fremont had a slight brownish tinge to the paint as a result of the marijuana fumes
              • Jon #40768
                Re: I live 20 minutes from Fremont. Thanks again *NM*
