'64 turn signal question - NCRS Discussion Boards
  • Gary H.
    • May 31, 2004
    • 48
    Turn signal works OK left, but not right. Switch moves to right and detent is fine. Does this sound like a turn signal switch or a flasher unit problem? Thanks.
    Gary
  • Joe R.
    • July 31, 1976
    • 4547
    Re: '64 turn signal question
    Gary,
    Flashers have no brains, so they don't know their right from their left. If it works one direction it nearly 100% eliminates the flasher. If the green indicator comes on and does not flash, check and see if the parking lamp and rear tail light are on. Then check to see if your brake lamp comes on. If one is not on you have a problem with that lamp or the turn signal switch in the column.
    Good luck,
    JR
    • William V.
      • December 1, 1988
      • 399
      Gary
      With the trouble you described, 99% of time it's a bad bulb on the side that does not flash.
      • Gary H.
        • May 31, 2004
        • 48
        forgot to mention in my original post that all the bulbs work. nuts.
        • William C.
          • May 31, 1975
          • 6037
          Run the check again with the parking lights on. You may see a difference if there is a ground problem at the socket
          Bill Clupper #618
          • Gary H.
            • May 31, 2004
            • 48
            Same result with parking lights on - left works fine, lever moves to right detent, but no signal. No dash indicator either. Where can I get a steering wheel puller ? ;-)
            • William C.
              • May 31, 1975
              • 6037
              you can make on from a piece of flat stock, borrow or rent from many parts houses, or try Harbor Freight by mail order or local store.
              Bill Clupper #618
              • Gary H.
                • May 31, 2004
                • 48
                Thanks, guys - this is my first of what I'm sure will be many questions. :-)
                Gary
