Adjusting headlight bucket mid-year - NCRS Discussion Boards
  • Bill S.
    • August 31, 1999
    • 104
    My passenger side headlight bucket has to be moved to the right in order for the correct gaps to be established ------ looks to me as if it's a dis-assembly type of job? Am I correct???
    Bill
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Adjusting headlight bucket mid-year
    No. There is a Y-Stop on the inside pivot and a locking ring on the outside. With these loosened it will slide. However, if it hasent been apart lately, all bets are off, because it is probably stuck in the pivot bearings.
    • Gerard F.
      • June 30, 2004
      • 3803
      Bill,
      As Wayne says, it's the Y bracket on the inside and locking ring on the outside which determine the horizontal position of the bucket.(I think he said that in different words).
      Try loosening the Y bracket first and move it inboard to get your gap. You can use wood shims to set the gap. Then tighten the y bracket. Then loosen the outside ring amd move it inboard so that the bucket is tight in position.
      You are going to wish you had eyes on your fingers. Also, don't tighten up too much on the bolt on the Y bracket; its cast aluminimum and will crack. Mine did and I replaced it with a cast steel bracket from Paragon. Also check your inner pivot mount, mine was also cracked.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
