Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 1962 engine block date code - NCRS Discussion Boards
  • David J.
    Infrequent User
    • May 31, 2000
    • 28
    I know this is a simple one, but. Can you tell me where I would find the location for the cast date code on a 62 vette with 340/360 HP?
  • David J.
    Infrequent User
    • May 31, 2000
    • 28
    Re: 1962 engine block date code
    The owner found a code on the passenger side top of B244. Does this come out to February 24th 1964? The block casting number is 3782870.
    • Bob R.
      • June 30, 2002
      • 1595
      Feb 24 64 is correct.
      • William C.
        • May 31, 1975
        • 6037
        Re: 1962 engine block date code *NM*
        Bill Clupper #618
