I found that the previous discussion on this subject, has opened up a new area of questions for me.
In Colvin's book "Corvette by the Numbers", he lists spec's for the '65,'66,'67,'68,'69 & '71 big block camshafts. I am particularly interested in discussing the specs for the L78, L72, L71 & LS6, mainly because these were street engines.
What I find interesting is that the '65,'66 & '69 camshaft list part # 3863143. While '67,'68 & '71 camshaft list part # 3904366.
What is confusing to me, is that the camshaft for '65, '66 & '69 all have different spec's from each other. Different lifts, both intake & exhaust, different durations (except '66) both intake & exhaust.
Yet, the '67, '68, '69 & '71 camshafts have the same spec's, but two different camshaft #'s are used?
And how can the '65 & '66 camshafts have the same part # with different specifications?
I am also interested in knowing which camshaft of the three different
spec's listed :ie the '65 L78, '66 L72 & the '67 L71 would make the most power, all other engine spec's being the same (same cfm, intake style, combustion chamber style/volume, compression, etc). Because I don't understand whether greater lift is more advantageous or longer duration, is.
And last how can the '67,'68,'69 L71 & '71 LS6 have the same spec's but different camshaft part #?
I find these mysteries intriguing, somehow.
