I'm doing a body off restoration working on the reassembly of the frame. After hanging the trailing arms and strut rods, I noticed the top of the strut rod bracket is sloped to the front. Is this common, normal, or what? The cam adjusting bolt appears to be at a slight angle also. Should the strut rod bracket be taken off and straightened?, ie. made flat on top? Can this be done without jeopardizing the integrity of the part?
Strut Rod Bracket
Re: Strut Rod Bracket
Pete-----
I'm not sure what the "phenomenon" is that you're observing. However, I can tell you this: although there were 3 different strut rod brackets used during 63-79 period (63-67, 68-74, 75-79), NONE of these brackets have a "sloped" upper surface. Also, the differential case mounting surface is not "angle-milled" in any way.
Besides this fact, I've never seen one of these brackets that was distorted as you describe. Actually, I don't even see how it could occur on the car. However, if your bracket is, in fact, distorted, then I would recommend making no attempt to straighten or repair it. In that event, you need another bracket. Unfortunately, all of the brackets are GM-discontinued and, as far as I know, are not currently reproduced. Used examples which are not distorted are not that difficult to locate, though. The 63-67 bracket is uniquely configured and a later bracket cannot be used. The 2 brackets used for the 68-79 period are identical except for an extra "tab" used on the 75-79 version as a mounting point for an exhaust system heat shield.In Appreciation of John Hinckley- Top
Interchangeability of Strut Rod Brackets
I read Joe's response and I recall reading somewhere that a 68 style bracket can be used on a mid year to lower the rear of the car slightly or enhance handling. I do not recall the specifics of this but I wonder if anyone else knows of this.
Scott Marzahl- Top
