63 PARTS Available? - NCRS Discussion Boards
63 PARTS Available?
  • `Michael Southard
    63 PARTS Available?
    SO, what are my chances of finding a 63 differential, and heads for a 63 L-76?
  • Tom D.
    • September 30, 1981
    • 2126
    100%
    The heads are generally available. The rear is going to take more searching...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • G B.
      • December 1, 1974
      • 1407
      Depends on your pickiness
      If you are actually looking for near-perfect assembly line parts with certain date codes that are being sold within a short distance of your home at rock-bottom prices, then you will be looking forever.
      • Donald T.
        • September 30, 2002
        • 1319
        Re: 63 PARTS Available?
        Check with Darrell Shepherd at 4 speeds by Darrell. He has a large inventory of differentials. I have worked with him in the past and was able to acquire an original differential with the correct ratio and date code, with just a phone call. Be prepared to pony up some $$$.
          Michael-----
          The chances of finding a NOS 1963 differential unit of the correct date code range is as close to "zero" as just about anything could be. The chances of finding a pair of NOS cylinder heads of the correct date code range is about the same.
          However, the chances of finding good USED, restorable pieces are VERY high. A lot of 1963 Corvettes which once were are no longer and the differential units that they "donated" to the Corvette parts world are out there. They die a harder death than the cars.
          The cylinder head castings, GM casting #3782461, were also used on 1963 Chevrolet cars with 300 hp engine and are not particularly rare, at all.
          • Verle R.
            • March 1, 1989
            • 1163
            I just passed up a nice pair of 461 heads complete for about $200 at a swap meet Saturday.
            Verle
            • `Michael Southard
              What were the cast dates? I have 461 heads, just dated too late.
              Where was the swap meet?
              Mike S.
              • Verle R.
                • March 1, 1989
                • 1163
                The casting date on both heads was March, the swap meet was Chickasha, Oklahoma.
                It was an individual, not a business vendor.
                Verle
                • Harry Sadlock
                  Mike, for the heads take a look at: http://www.tracyvette.com follow the links to the vette area for heads. They have them listed by PN and year. Give them a call for a set and a rebuilt set. This will help set a price point for you.
                  Harry
                  38513
                  • Mike Cobine
                    Unless you are heading to
                    a judging meet in the next few weeks, I'd use whatever rear and heads you have right now and scour the swap meets.
                    461 heads are plentiful. I see them quite often in the $200 range for used and $350 machined and ready to bolt on.
                    The rear is a harder part to find.
                    Scour the Driveline and any Corvette swap meets. The Chicago Chevy Corvette Fest is coming up in November and there will be a ton (pun intended) of rear ends there. The Turkey Trot Show at Daytona is Thanksgiving and covers the infield, if you need a clue as to how big.
                    Check Hemmings both for ads and for dates on swap meets.
